So excited tonight to upgrade the firmware to the unleashed so that I can finally use it for long exposures on my Sony A7IV.
But I seem to have entered a firmware update doom loop and the unleashed appears not not be usable anymore,
The update first seem like it was doing well, and then it stalled. Yes, I was pressing the shutter on the camera so that it would not go to sleep.
I am sharing two screenshots that will give a glimpse of what is happening.
https://www.dropbox.com/scl/fi/t27l3984 ... 406u3&dl=0
https://www.dropbox.com/scl/fi/ejet99x9 ... e7j0x&dl=0
This is so frustrating,
Pierre
						Firmware update doom loop [solved with FW C3.3.1]
😱 Sorry about that, looks like a change in our bootloader to improve firmware flashing during production caused another error that we did not catch. We have reverted the firmware versions to A3.2.1 B3.2.1 C3.1.0, so you should be able to "downgrade" by hitting update again. You might have to delete the app and re-install it, to clear the previously downloaded 3.3.0 version.
the downgrade will keep telling you that the firmware is up to date, instead of showing the percentage. You can ignore the message and watch the LED of the Unleashed instead - it should be blinking blue while it's updating.
We'll try to publish a fix tomorrow, should that not work!
