Got my Unleashed a few weeks ago through the Kickstarter campaign. Had a lot of problems initially getting it connected and properly working, but after many iterations of plugging/unplgging it and powering up the camera vs. the Unleashed, I finally got it working and I just updated it to the latest firmware.
However, I'm not able to control the aperture setting even when everything is set to 'A' or 'C', respectively. I have have read about similar issues with the X-H1/H2 here a while ago, but there didn't seem to be a conclusion of the issue at the time. Was wondering, if there is an update regarding this?
						Fuji X-T5 aperture control [solved with Menu Setting]
We have fixed all the issues we know about with Fuji, so the old posts should no longer be relevant.
Could you be more specific, and share some screenshots and photos?
I just found this video to see if we missed something, and indeed:
If you set your lens to A, you also need to define what "A" means in the camera menu. You have the options "Auto" and "Command". You need to set that to Command.
I found this video that shows it quite well:
https://youtu.be/vH7Jr4V-NWI?t=40
I hope this is what you need!
Basically, if you can use the camera's thumb command dial or index finger dial (if your camera has one) to change the setting, rather than a dedicated dial or aperture ring, then the Unleashed will also be able to control that setting.
Happy Holidays!
Happy Holidays!
						The ISO dial on the X-T4 has a dedicated Command "C" position next to the "A". Set it to "C" for the Unleashed to be able to set ISO values.
Older cameras like the X-T2 don't have the "C", but do have an "A", together with the Menu entry where you can choose that the A position should be used for "Command"
