hello you all
I recently discovered the awesome flex interval feature for holygrail timelapses. But unfortunately, I'm not able to test it out as it's not working. I set all my parameters but when I tap the shutter button in the app, nothing happens. The usual timelapse mode works perfectly fine, as the simple photo mode
Am I missing something when setting it up or is something going wrong here ??
thank you very much for your help
(firmware up to date as A3.1.2, B3.1.2, C3.1.0)
Flex interval not working on my GH5 [solved with FW A3.1.4]
I have the same issue with flex interval on lumix s1. The timelapse doesn’t start after pressing the shutter button
Hi and sorry for the silence in the last two weeks. I was away for a few days and have been catching up since - I'm only getting to the forum today!
I thought I had answered this thread, before my trip, but it looks like it was a different one with the same issue - here's my answer in that one:
viewtopic.php?p=5327#p5327
However, with the firmware update we issued today, Flex should be available for all cameras. On some it will work better than on others, but we do have a plan for improving this across all brands even further in the future!
Thank you very much Oliver. I will check it out asap!
