Preview downloads jpeg and raws [solved]
I just tried this on a Nikon D7100 and I couldn't reproduce this issue. Only one thumbnail is downloaded. It might be that other cameras behave differently, I'll test later on other cameras and I'll let you know what I found.
A quick follow-up question: are you saving JPG and RAW to seperate SD-Cards?
We specifically programmed the Unleashed to check if the camera is set to RAW+JPG and if so, only fetch one thumbnail (of the jpeg, since it will be faster), but I don't think we tested the case where they are saved to two different cards.
I received my Unleashed yesterday :) and have only done some basic things so far. One of those things was trying out the preview and I too found that two previews loaded when I took a photograph. I most often shoot in RAW only and have my second SD card set as Backup. I then did some experimentation and got the following results. I ran through the setups a few times and triggered the shutter from both the app and directly from the camera.
Combinations of settings that usually produced 2 previews yielded only 1 preview on some occasions. With these combinations, triggering from the app always produced 2 previews and mostly so did triggering from the camera. Single previews could be observed the first time that the shutter was triggered from the camera after having taken photos with the app; however, this didn't happen in every instance. Also, subsequent shots from the camera could again produce single previews but usually reverted right away to 2 previews. Seeing two previews when set to Backup could be because the camera does actually save the images twice. It seems strange to see two previews with quality set to RAW but cards set RAW slot 1 + JPEG slot 2, but it turns out that the camera treats this configuration as a backup, saving the same RAW image to both cards, so again the camera is saving the image twice.
Peter King
Nikon D750 firmware version C1.12 L2.016
iPhone 5s iOS version 12.0.1
Unleashed N2 version A1.0 B1.0 C1.1
Unleashed app version 1.0.0 (391)
Thanks Peter, for taking the lead. I went so far as validate the raw&backup causes preview to show two images.
@Andy: I wonder if you should consider the timestamp of the files. In bursts with 12 pictures per seconds you might not want to download all either? Don't know.
Nikon Z6.
Nikon Z6.
