Autoramp Algorithm
sorenbunnyjensen
March 5th, 2021, 8:02 am
My only algorithm option when using autoramp is: "EV-meter Smoothing 24H" ... Should there not be more options available ?
March 5th, 2021, 8:31 am
I assume you have either an N1 or an N2? Do you have the USB cable plugged in? You need it for the Unleashed to be able to work with images for the LRT algorithms.
sorenbunnyjensen
March 5th, 2021, 8:50 am
arh yes ... I have not plugged the cable in... thanx
