Google Mobil Service
Nerdlinger
November 1st, 2020, 3:41 pm
Hello...
are required for pairing Google mobile services...?
Have a beautiful Sunday.
November 2nd, 2020, 10:40 am
no, I believe Google Services are not required.
Nerdlinger
November 3rd, 2020, 1:10 pm
...OK thank you
Pairing with my new Huawei P40 Pro
it does not work. The cell phone recognizes the N2 as
Bluetooth device. But not the app ...
November 3rd, 2020, 3:07 pm
You need to give the App permission to Location services. Google changed this with Android 7, if I'm not mistaken: since certain methods of discovering Bluetooth devices can also be used to determine a location (eg using Bluetooth Beacons), Google put finding Bluetooth devices under the Location services permissions. Unfortunately, discovering the Unleashed falls under the same, so even though we will not use your location until you actively turn on the GPS setting, you still need to give the Locations permission to the App. Other than that, the Android Bluetooth Stack has some issues every now and again, in which case turning flight mode on and off has often helped tremendously.
I hope this helps!
Nerdlinger
November 5th, 2020, 6:58 pm
All authorizations are granted, only the Bluetooth authorization for the location cannot be set to "permanent". Only when Bluetooth is in use.
The old cell phone makes contact.
Maybe I'll try updating the firmware for the N2
Nerdlinger
December 24th, 2020, 2:20 pm
It seems to be due to the hardware.
The previous cell phone no longer
connects with the Unleashed.
What can I do...?
Have a Merry Christmas ...
December 26th, 2020, 11:04 pm
There are a few known issues with Android, but unfortunately they are out of our control, as they come from bugs in the Android Bluetooth stack.
These things have helped many customers:
- turn airplane mode on and off again.
- clear Bluetooth cache
- clear App cache (or delete App and reinstall)
- restart phone.
typically airplane mode seems to do the trick!
