I'm on Nikon D500 and each time I try to use the TIME option, after about 30 seconds, it locks me out and can't stop the shutter. It keeps telling that to save energy is in saving mode. However after trying pressing everything it won't allow me to stop the shutter of until I manually do it on the camera.
https://drive.google.com/file/d/1-b7kab ... p=drivesdk
Time mode - Timing out [solved in FW update]
Thanks for the report. We'll have a look if it's an app issue or Firmware.
Have you tested the emulated TIME mode (set the normal Shutterspeed to BULB, and use TIME in the Long Exposure Setting)?
The bulb setting mode works fine, it's the other setting mentioned that have me problems.
