Sony a7CR Bug after Firmware Update 2.00
897t94
May 3rd, 2025, 10:49 am
After updating my Sony a7CR to the newest firmware 2.00, I can´t set any other shutter speed than BULB anymore. In the app it always switches back to BULB if I set any other shutter speed. I made a video that shows the behavior: https://imgur.com/a/m1Fojob.
Once I set it to BULB, it doesn´t switch anymore, but then the fastest setting I can choose is 1s in "Langzeit" as a workaround, but that doesn´t make sense in most cases.
outthere
August 12th, 2025, 9:01 am
Hi, I have the same issue with my Sony a7c II. Have you found a solution in the meantime?
August 15th, 2025, 6:05 am
Don't have high hopes of getting a solution. If you get a solution, it would be a miracle.
We have seen many broken promises repeat itself here. There is still, after all those years, no solution to the battery draining problem.
I do hope I am totally wrong about this, but I don't think so in the long run.
November 29th, 2025, 12:30 am
Kokore wrote:
November 12th, 2025, 4:36 pm
@Oliver (admin)
do you think you'd ever address this bug?
I bought the unleashed last spring, and have never been able to use it because my sony A7cII was already upgraded to firmware 2.00
As you never answered to my refund request, nor to this thread, I feel like the support from your company is non existent...
Throw the damn thing away! Forget about your refund. This product and company is dead. Don't waste anymore time on thinking back on this project, product, company.
