Unleashed 22 - Canon 5DMKIV - No Power
lgw
October 26th, 2023, 10:26 pm
I've just got my unleashed 22 and connected it to my Canon EOS 5D Mark IV, to find it has no power.
Camera is on Firmware 1.4.0 and I can't see any settings related to USB/HDMI being enabled etc... not sure if I've missed something or just got unlucky with a faulty unit?
October 27th, 2023, 10:52 pm
I believe you might have managed to insert the cable into the Unleashed the wrong way round! There is a slot and key that should stop you from doing so, but because the casing is plastic, it’s possible to overcome this. But don't worry: we designed it so that even if you do manage, it won’t break anything - it just won’t work.
The LED won't light up, the Unleashed M won't get any power so it won't show up during pairing.
On the Unleashed M, plug the cable into the Unleashed so that the cable points toward the right, ie toward the back of the camera.
I hope that does the trick!
lgw
November 4th, 2023, 11:03 am
Hi @Oliver,
I have now got the unleashed to power on and pair, but get an error that the USB mode is wrong. I can't find the option to change this on the camera.
Any ideas?
November 4th, 2023, 11:34 am
Hmm, that's odd, the 5D Mark IV shouldn't show such an error.
Have you updated your firmware? Whenever there's a Firmware update available, you'll see a red notification badge on the menu icon in the bottom left corner of the app. Follow this notification badge through the app to get to the firmware update screen.
can you send a screenshot where you see this message, or copy the message exactly?
lgw
November 5th, 2023, 12:23 pm
Please see screenshot
November 12th, 2023, 12:31 am
Yesterday, we published a firmware update (A3.1.1 B3.1.0) - could you check if this solves your issue?
