A7s iii connection not working
I get my unleashed connected to my phone, but unfortunately can't control the camera. When I go into the camera settings I am always brought back to the home screen after about 5 seconds, I have had this bug before when I connect an HDMI device. The USB remote function I think has been moved and is no longer there as shown in the tutorial (I think it is now in Network and Transfer/Remote and no longer in Setup and USB). I have at least tried all the settings and also get -PC- on the screen of the Sony displayed, but in the app the error that it can not control the camera.
In the last update we made critical improvements -especially for Sony.
Did you see the Getting Started page?
Your camera is one of the first ones that have the new menu, so you have to look at the instructions for the > 2019 Sonys with the new menu.
- MENU > Setup > USB > USB Connection Mode > PC Remote.
This automatically sets:
MENU > Network > Transfer/Remote > PC Remote Function > PC Remote > On and
PC Remote Cnct Method > USB
- If previously connected to Image Edge Mobile app via WiFi Direct, disconnect
- If previously set to transfer FTP over USB
Set the camera setting: MENU > Network > Transfer/Remote > FTP Transfer Func. > FTP Function > Off
I already updated the firmware. As I said, I switched the PC-Remote on (even the setting is somewhere else). But it's still not working. Unleashed is connected, Camera is showing PC remote, but app says USB not working. I switched the Airplane mode on. Under USB Connection as described from your side I can only choose Auto, Mass Storage and MTP. If I switch to MPT unleashed says it's initialising, but nothing changing for 5 min.
Hope you have any idea. If you need any information for debugging, just let me know or give me a call.
Justus
Justus
Did the last firmware fix this issue for you?
If not, could you send a photo of the USB Setting you have set your camera to?
There are a few different places in the camera menu for PC Remote.
We found out that there are some cameras that are in between the old and the new kind, which don't have the "PC Remote" option in the USB Connection mode, but instead you need to set it in two other places:
A7R IV (AND MAYBE OTHERS CA 2019)
- MENU > Network > Transfer/Remote > PC Remote Function > PC Remote = On
- PC Remote Cnct Method = USB
we added this info to the Getting Started website:
