Intervalometer sony zve10
eddie71
March 10th, 2023, 12:34 am
I have a sony zve10 and when i use the internal intervalometer I am only able to autofocus on the first shot, will I be able to autofocus before every shot when using the intervalometer with unleashed?
Natasha
March 10th, 2023, 11:16 am
Hi Eddie,
if your camera is set to autofocus, then yes, the Unleashed will also focus before each shot. However, for the best timelapse results it's usually recommended to switch to manual focus and set it perfectly before starting the timelapse so that the focus stays in exactly the right spot throughout the timelapse. Otherwise it may shift midway through and lead to odd results. Your specific use case may of course require the focus to be "updated" on every shot, so this is just a recommendation :)
eddie71
March 14th, 2023, 11:01 pm
Hi Natasha,
Thanks for your reply to my question, I need the autofocus before each shot they are self take trophy shots.
Eddie
