- When waking up from standby, and clicking on Flash Comp, the text reads 0.0 but die dial at the bottom shows -3.0. Clicking on the same button again sets the dial to 0.0 as well.
 - Timelapse calculation screen is not initializing correctly. I have set the interval to 1s, duration 1 minute and it shows correctly that 61 photos will be taken and the clip length is 2s at 30fps. Now switch to Video mode and back to Timelapse. It will show above settings except the clip length is reported as 6s now.
 - The Unleased says in the notification bar "Sending geotagging data". Don't like that text. Especially as it is showing that text even if GPS sending is turned off in the Unleashed app or the camera is off.
 - In the Timelapse screen, when the camera is turned off, a red stop sign is shows. I like that. Show it in the Photo and Video screens as well, would be my proposal.
 - In Photo mode and when the camera is turned off it says "Photo trigger is read-only" and "Camera is off". The first line does not make sense, show the others only.
Little UI issues
Nikon Z6.
						Nikon Z6.
Turn on Camera, open the Unleashed app, click on the Flash Comp setting. The button does show 0.0 and the selector at the bottom screen as well.When waking up from standby, and clicking on Flash Comp, the text reads 0.0 but die dial at the bottom shows -3.0. Clicking on the same button again sets the dial to 0.0 as well.
Click on any of the other buttons, e.g. WB.
Now wait for the camera to go into standby (=Metering off).
Once all buttons are grayed out, click the Flash Comp button.
It takes a few seconds for the camera to be connected via USB, then the Flash Comp button correctly shows 0.0 but the selector at the bottom -3.
Note: Do not touch the camera, else the behavior is correct. The Unleashed should wake up the camera.
https://photos.app.goo.gl/YvPuYCMErrpUbUrr5
Nikon Z6.
						Nikon Z6.
Don't know why you cannot reproduce it.Timelapse calculation screen is not initializing correctly. I have set the interval to 1s, duration 1 minute and it shows correctly that 61 photos will be taken and the clip length is 2s at 30fps. Now switch to Video mode and back to Timelapse. It will show above settings except the clip length is reported as 6s now.
Go into the timelapse mode and select interval=1s and duration=00:01.
Clip Length reads 2s.
Now go into the Photo page.
Now go into the timelapse screen again and check if the Clip Length says 2s or 6s as in my case - screenshot below.
https://photos.app.goo.gl/UDMjE1ApQhLNoYTK9
Nikon Z6.
						Nikon Z6.
