photojourneyman
April 2nd, 2024, 5:24 am
BorisH wrote:
February 27th, 2024, 3:56 am
Is there a estimated timeline for the implementation of this new way to 'flip' the algorithm automatically?
Hi Boris, I am curious to know if you have tested unleashed with the A7R5; I have had my unleashed for several weeks Holy Grail is not working for the A7R4 or the A7R3. Most commonly, aperture is ignored in the ISO-AV-TV sequence so it stays locked in the aperture I start with. Other times exposure has severely spiked on sunrise before ramping back down. I have tested it many times with different settings, sunrise and sunset, and have not a single succesful timelapse. I am using it in combination with LRTimelapse so it is easy for me to check the metadata. No response so far to my bug reports. I will be returning my unleashed if I can't get this to work.
BorisH
June 26th, 2024, 5:34 am
Hi @photojourneyman,
No, I have not tried it much with the A7R5.
First time I did, the camera was not compatible, so I haven't yet gone back to it.
I can see it's now in the compatibility list, so I might try it again when I'm back home by the end of this week.
(Also sorry, haven't received notification about a new message, so didn't see this for a while)
StefanGL
November 2nd, 2024, 7:37 am
Good morning!
Is there any news on this feature? It's been almost a year since the request popped up.
March 7th, 2024, 12:49 pm
it's on our to-do list, but not yet near the top, so I can not give you an estimate a the moment.
Thanks a lot in advance,
Stefan
richardallan
November 12th, 2024, 7:30 am
Hi Stefan. It appears that there is no longer any support for this product. I have been using it successfully with my A7RV but unfortunately, since the latest firmware update, the interval setting changes for some reason. This setting should stay constant but if I set my interval to 8 sec, for example, after about an hour it jumps to 12 sec! I can't find any reason for this or any method to change it.
StefanGL
November 16th, 2024, 8:04 am
Hi Richard!
It would be sad and frustrating if announced features will never come. Even more so if there are still bugs to be fixed, like the bug you mentioned.
Can anyone from the Foolography team confirm or disconfirm that there is no longer any support / development of this product? Thank you.
mopperle
November 17th, 2024, 12:36 pm
Has anybody of you tried to contact via their support form?
https://www.foolography.com/support-form/
And did you ever get an asnwer=?
Otto
