I'm testing my new Unleashed, but in Holy Grail I can't select an algorithm. The only voice is none. my camera is set up all in manual. thank you.
Fujifilm xt-2 algorithm selection [Solved with RAW+JPG]
We recently made some important updates for Fujifilm, so please make sure your firmware is up to date.
Then, please set your camera to Raw+JPG. There are some issues with just RAW on Fujifilm cameras that we could not work around, but using raw+JPG should give you some options for the Algorithm
I hope that helps!
I hope that helps!
