Fujifilm xt-2 algorithm selection [Solved with RAW+JPG]
davprim
October 30th, 2023, 5:51 pm
I'm testing my new Unleashed, but in Holy Grail I can't select an algorithm. The only voice is none. my camera is set up all in manual. thank you.
October 31st, 2023, 11:34 am
We recently made some important updates for Fujifilm, so please make sure your firmware is up to date.
Then, please set your camera to Raw+JPG. There are some issues with just RAW on Fujifilm cameras that we could not work around, but using raw+JPG should give you some options for the Algorithm
I hope that helps!
davprim
October 31st, 2023, 11:48 am
Hello Oliver,
my firmware is up to date . With raw+jpg I can select the lrt algorithms.
Thank you!
