After month in Hospital i tried to reactivate my Unleashed Hardware on my Nikon D7000 but ended up with a mess, the LED is blinking red and the update process stucks at 0%
don't know why the image doesn'T show up correct, here'S the link to my web http://www.stereomusic.at/tempUL/D7000unleashed.png
any help would be appreciated
by(e)
Khun Otto (ออตโต้ ซเติฟคา)
[solved] Firmware Update Nikon D7000 failed
Hi!
I see that your serial number is below 4500, so we almost definitely have a fix for you. You will not believe this but the following trick will almost definitely help: Put the Unleashed in the freezer for 10-20 minutes, then plug it into the camera and try the update again, while it’s still as cold as possible.
We took a long time trying to find the cause of this problem. We found the problem and fixed it, but the fix comes in Firmware A, so if there’s ever a problem during the update of Firmware A, the fix will no longer work either.. The trick with the freezer has a scientific explanation too - now that we know the underlying cause.
I hope it helps!
I hope it helps!
after half hour in the freezer the hardware was cold, plugged in my Nikon, but can't even connect to the app
http://www.stereomusic.at/tempUL/Screen ... 080847.png
only red blinking from the LED
http://www.stereomusic.at/tempUL/VID_20 ... 080926.mp4
any help would ne appreciated
BTW i wrote an e-mail in german language also, if you prefer to answer there
by(e)
Khun Otto
by(e)
Khun Otto
