Shutter Speed in Bulb and T [added in FW 1.3.0]
Hi This is the reason I got an Unleashes - so if in blub can we have a timer we can set so we dont have to hold down the shutter button for the time we want the timer to run? Or better if we take a light meter in any mode and set shutter speed or Aperture it would give us a long exposure past the 30 seconds limit on the camera. This would be useful say after setting up a shot and then adding a ND filter and needed to expand the exposure x the filter?
Any update on this?
I for one need the ability to set exposure durations longer than 30 seconds. Typical time needs for me are upwards of 5 minutes, some longer. Setting in one-second increments works great for me. The ideal situation would be a software intervalometer where I can set duration, a delay between exposures and how many exposures to do in a session.
Mark
Nikon D810
iPhone-X
iMac
Mark
Nikon D810
iPhone-X
iMac
Hi mrainer,
we're working on many other things at the moment - right now we had to prioritise our second product line before we'll get back to the Unleashed. The emulated long exposure times is very high on our list.
In firmware this feature actually won't require very much work, but we were torn between two (very different) approaches to designing the UI for this feature. Your comment brings up a good point that we had neglected so far, and makes one of our two choices much more favorable. Or rather opened a third option that might be a good compromise.
But don't worry, the long exposure feature will DEFINITELY come! I just can't yet promise when.
I just wanted to ask if there is an update concerning the emulated long exposure times. I would be really interested, as this is the feature that would save me always taking a look at my watch while taking long exposures.
Thanks
Christoph
Thanks
Christoph
Hi chruztoph!
Yes, this has been implemented, and has been available as firmware and App update for all Unleasheds for quite some time.
You can now do long exposures up to 4.6 hours, in third stop increments!
This results in slightly weird times, but it means you don't have to pull out a calculator when using ND filters.
