GL-770
Ruediger
August 17th, 2021, 9:00 pm
Hi there!
I have just a little question: I paired my two Unleashed with the app and I separately paired my GL-770 with both Unleashed. Is it right that I can only receive GPS data from the GL-770 to one of my Unleashed at the same time?
Kind regards!
Rüdiger
August 17th, 2021, 9:14 pm
Hi Rüdiger,
Yes, the GL-770 only allows one Bluetooth connection at a time.
This means you can have both Unleasheds paired with it, but only one can connect at the same time. This is fine if you usually only go out with one camera body and leave the other one at home, but if you want to use both at the same time (eg with two different lenses), then only one will have the direct connection to the GL-770.
Ruediger
August 18th, 2021, 7:38 am
Hi Oliver!
Thanks for your quick answer!
