Trying to get Live Working on my D850 [solved - not possible]
Hi Radwar,
Unfortunately Live-view is not one of the Unleashed's features.
We only support transmitting small thumbnails of an image for quick review and checking exposure after you've taken a shot.
For this you need to connect the small usb cable included with your Unleashed, and in the photo screen, at the bottom right, tap on the thumbnail icon. then slide the switch to enable "Photo review", and take another shot.
We are going to work on Live-view as well, but because of the bandwidth limitations of BLE, it will certainly not be a smooth stream of high-resolution video. We will try our best to get something useable, but even that will be difficult to achieve, and will still take quite some time!
						If you unplug the USB cable, you can use Liveview while the app is in the foreground.
If the usb cable is plugged in and the app is in the background (eg phone screen is off), you can also use Liveview.
If the app is running in the foreground and the USB cable is plugged in, Nikon does not allow Live-View to be on. I have no idea why they do this, but it's a limitation we have to work with.
						From: https://www.foolography.com/faqs/why-do ... all-cable/
									On all Nikons, the USB cable enables getting thumbnails, and also activates some extra settings, most notably metering mode (Spot/Matrix/Centerweighted). It also makes automatic switching to Video mode a little easier.
