Unleashed for D700 on D4?
Posted: April 11th, 2021, 11:27 am
by paolone
Hi all,
I have an Unleashed I currently use with my D700. Can it be used on a Nikon D4? From an hw point of view there should be no problems, does the firmware support D4 also?
Thanks
Paolo
Re: Unleashed for D700 on D4?
Posted: April 11th, 2021, 11:56 am
Hi Paolo,
yes, the Unleashed N1 for the D700 will fit directly on the D4. Both cameras even use the same Mini-USB cable, so you're good to go. Just unplug it from the D700 and plug it into the D4. It will just work.
Small note for unplugging: try to grab it on diagonal corners and slightly wiggle it while pulling it out. It fits very firmly, so it's not very easy to unplug ;-)
Posted: April 11th, 2021, 12:18 pm
by paolone
Thanks for the clarification and unplugging tip!
Paolo
