Support Canon D5 M IV with RRS L-Plate
Posted: February 23rd, 2021, 3:13 pm
by maruoff
Hi community,
I'm using a Canon D5 Mark IV with a L-Plate from Really Right Stuff (RRS).
Do the UNLEASHED fit anyway ?
The access to the connectors are a little bit narrowed.
Do you know this or does anyone in the community aware of this?
thanks maruoff
Re: Support Canon D5 M IV with RRS L-Plate
Posted: February 25th, 2021, 10:30 am
We have many users with L-Brackets, but because there are so many types for so many different camera models, I can't give you precise compatibility information for each combination.
Most L-Brackets have a cutout for the ports, and because the Unleashed is so small, chances are high that it will just fit into the cutout.
Even if not, most L-brackets have a slot instead of just a hole for the tripod screw that attaches to the camera. This allows you to slide the L-bracket over a little, to allow a bit of space between the left side of the camera an the L Bracket. you only need an additional 5-10mm to have enough space for the Unleashed.
https://www.foolography.com/faqs/is-the ... -brackets/
