Flash Control
Posted: September 27th, 2024, 9:51 am
by garym2024
Hi, can anyone tell if the the app is able to turn the flash on and off, I have a D850 with a Godox V1 mounted on the hot shoe
Re: Flash Control
Posted: September 27th, 2024, 1:33 pm
Not directly, no.
You might be able to do something like setting up a custom Mode such as U1 on your camera to have Flash turned off, and normal mode (M/A/S/P) to have flash enabled. then use the Unleashed to switch between the modes.
I'm not sure if that's possible with the D850 though.
Re: Flash Control
Posted: September 27th, 2024, 4:32 pm
by garym2024
The D850 uses 'Photo shooting menu banks' as custom settings. Is alternating to these supported?
Re: Flash Control
Posted: September 30th, 2024, 2:19 pm
Hmm, I just double checked: and the D850 does not have Modes such as U1 or U2
https://onlinemanual.nikonimglib.com/d8 ... re_02.html
Unlike Cameras like the D7000 series:
https://onlinemanual.nikonimglib.com/d7 ... gs_02.html
So unfortunately, there is no way to do that at the moment.
I guess as a workaround it might be possible to find some other setting which disables the flash sync But I can't think of one that can actually be changed on the d850 (on other cameras, driveMode might have been a candidate)
