Canon R7
stnicolae
January 24th, 2023, 7:42 am
Will you support the two new mirorrless cameras from Canon (R7 and R10) anytime soon?
If the answer is yes, what version should I order? M1?
Natasha
January 24th, 2023, 1:08 pm
Hi! The R7 and R10 will both be compatible with the Unleashed M with a USB-C magnetic plug and HDMI-D cable. You can go ahead and pre-order here: https://www.indiegogo.com/projects/unle ... x/15427115#/
You'll only need to make your final model choice a bit later though. We'll send you a survey for that once we approach shipping time :)
croimans
October 20th, 2023, 7:46 pm
i have R7 and it doesn't work yet unfortunately
