I've just flashed my unleashed with the new v2.0 firmware. Do you have any documentation on the new features available for the new version?
Thanks!!
Documentation on 2.0.0 Update
No, the Documentation is not quite ready yet, but we are working on it.
Most changes of this update are under the hood, and make the Unleashed a lot more stable and performant with the same feature set.
The only New Features that already available are the ND Filter setting, and the Advanced Unleashed settings.
the most important thing to know about the ND filter setting is that the values are in F-stops. So if you select ND+8.0 that's for an 8 stop ND Filter, when you select that, you'll see the Unleashed change the shutterspeed for you by 8 stops.
The Advanced settings (found in Menu->Unleashed with Gear icon -> Your Unleashed -> Settings) Do have some explanation below each setting, but We agree - we could certainly elaborate on those.
