difficulty removing from usb port
Posted: November 22nd, 2023, 6:11 pm
by lostrockets
any tips on removing from the usbc port? im finding it very difficult without using a tiny screw driver or tweezers since the magnet falls off. is there a better way?
Re: difficulty removing from usb port
Posted: November 24th, 2023, 1:46 pm
On many cameras, you can actually pull the magnetic plug out together with the Unleashed, if you very slightly wiggle it up and down while pulling it out slowly.
Instead of a screwdriver you should use what's called a "Spudger".
this usually gets shipped with any Smartphone spare parts, so if you don't have one already, any smartphone repair shop will probably have some to give away.
Alternatively, a guitar pick works really well, or the corner of a credit card, or of course some some longer fingernails ;-)
Posted: November 24th, 2023, 1:47 pm
I moved this topic to the Tips and Tricks forum, that fits a little better ;-)
