So, I'm going to use a Nikon Z8 to shoot a day to Milky Way to day timelapse (tonight, if I can get everything figured out), with my camera on a pan/tilt head and rail controlled by a Black Forest Motion Pine II.
I've been shooting this sort of thing for years, but have always controlled my cameras by hand (and moco with BFM app). I got the Unleashed specifically so I don't have to touch the camera (risking shake, a sequence-killer).
I've tried three times now to use the Unleashed in its simple photo mode, merely to control my Z8's exposure (and let the Pine II's app control exposures and movement). But, for some reason, I either lose connection to the Unleashed, or I can't change parameters while the timelapse is running, and sunrise gets blown out. That's about 30 hours of all-nighter time wasted testing :-(
So I've decided to try a full automated Unleashed setup, with fingers very crossed.
But I'm having trouble finding info on some of the Unleashed functions. I'd be very happy to be pointed to FAQs, Unleashed Community posts, manual pages, or even private blogs/vlogs regarding my questions below, as I've not had any success finding them myself.
1) what are the various "Flex" intervals (Flex, Flex5S, Flex180).
-I could run tests to figure them out, that would be many 10's of hours, better to read what they are!
-I have used an LRT Pro timer to ramp my day to night intervals successfully in the past, so I'm hoping that this is an automated version of that function (but, still, how are they implemented?).
Edit: of course, right after posting I stumbled upon this page which explains the below: https://www.foolography.com/faqs/how-to ... imelapses/
(I'm going to attempt EV24h algorithm, even though I do all my smoothing in LRTimelapse in post)
2) Holy Grail algorithms: which is good for what?
-I used to use qDSLRDashboard with a tablet with my DSLRs (I've been shooting timelapse professionally for about 15 years) and the LRT algorithm, and I loved the automation but also my ability to tweak the sensitivity-to-luminance values during ramping. Perfect results every time. On the Unleashed, using e.g. "LRT Sunset Beta" (or modified Beta), can I do the same tweaks? (can I alter the ramped exposures such that I get perfect exposure of the milky way during the shoot?).
-And what is "EV Smoothing 24h" (since I'm shooting sunset-->MW-->sunrise, I'd love to hear that this is the perfect algorithm to use).
2nd edit: with the help of Moritz at BFM, I found out that your Pine II has to be named "PINE II" (all caps) in order for the Unleashed to see it.
Of course, this is all moot if I can't succeed in connecting them via bluetooth. I'm using this vid https://www.youtube.com/watch?v=hjmhbdIPj-8, and the Pine is not showing in "Your Accessories" (firmware on both devices is fully up to date). I've rebooted everything, still no success :-/
3rd edit: almost there, but not quite. The Pine II and Unleashed are connected, Pine App is set correctly (moves have been programmed and it's in slave mode), Unleashed app is set (tested with a simple timelapse sequence), but the motors don't move. Very frustrating!
Challenges and challenges!
how to ramp from day to Milky Way to day? With Pine II motion control
Hey mate I’ve got an unleashed 18” and the 22”
Unfortunately work and dad life means I don’t have much time to tweet run features but I can try help with afew of ya questions.
So the flex options are interval ramping, if you select flex and start with a base interval of say 6 seconds and then set up your min/max shutter speeds-aperture for day/night and ISO for day/night then run it the unleashed will pure inteverval ramp all your settings up and down for sunset/Milky Way/sunrise etc.
So the interval will hard follow your shutter as it ramps up and down
Flex 5S is similar but it gives the camera a 5second added on interval to each photo as it ramps through to allow your cameras image review to show an image if needed.
Flex 180 is supposed to keep the interval exactly or close to double your shutter speed to give a somewhat cinematic look or something along those lines.
I don’t have black magic gear, run all syrp but unfortunately I really haven’t had proper time to test all the gear and auto ramping etc so can’t fully comment there.
As for holy grail algorithms, well that will depend on your camera.
With your Z8 I wouldn’t worry about them and just use the 24hr EV
The sunrise/sunset ones I really only found useful for a DSLR as they only ramp one direction, say sunrise only or sunset only etc.
Which works well for a DSLR as their light meter goes haywire at sunset and those ramping algorithms give them a good ramp.
The 24HR EV ramps both directions and works perfect for mirrorless as they have on sensor light metering.
On my Z6 and Z6ii it works perfect so that’s what I use all the time
Cynthianeale
ПРОМОКОД 1WIN актуальный абуз бонуски и ваучеров на 1win
Промокод 1win на бонус за установку приложения даёт игрокам преимущество, которое ощущается с первых минут после активации. Получая дополнительный ресурс, можно сразу тестировать разные игровые направления, проверять тактики, пробовать режимы, не рискуя основным счётом. А главное — бонус открывает доступ к повышенной активности: чем больше ресурсов в начале, тем быстрее игрок может оценить игровой баланс, выбрать подходящие режимы и сформировать свою стратегию. В приложении полностью сохранены возможности десктопной версии, но сама мобильность даёт чувство свободы. Ведь намного приятнее играть в любое время: в транспорте, в перерыве, на прогулке, дома — одним движением пальца. И именно промокод делает это свободное начало ещё более ярким.
1WІN ПРОМОКОД - promo4win
1WІN ПРОМОКОД - freespin4win
1WІN ПРОМОКОД - freebet4win
Как использовать бонусный счет в казино 1win
Использование бонусного счета казино 1win требует внимательности, но открывает огромный простор для экспериментов. Многие думают, что бонусный баланс — это просто временные виртуальные деньги, однако это полноценный инструмент, который позволяет тестировать слоты, изучать игру, увеличивать шанс на выигрыш и выполнять wagering более эффективно. Секрет правильного использования заключается в выборе подходящих игр. Лучше всего работают игры с высокой отдачей, стабильными коэффициентами и частыми выигрышными комбинациями. Если использовать бонусный счет в таких играх, можно максимально долго удерживать баланс и постепенно наращивать объем ставок. Выбор стратегии также играет важную роль: не стоит сразу ставить максимальные суммы — лучше начать с небольших ставок, чтобы продлить игру, изучить механику и подготовиться к моменту, когда появится шанс на крупный выигрыш. Дополнительным преимуществом бонусного счета является возможность пробовать недавно добавленные игры. Это позволяет игрокам оценить обновления казино, не рискуя собственными деньгами, а также анализировать, какие слоты подходят для будущей игры на реальный баланс. Бонусный счет — это безопасный тренировочный полигон, который позволяет вам чувствовать себя свободнее, увереннее и играть рациональнее.
https://www.youtube.com/watch?v=0a-oN7kCdm4
https://www.youtube.com/watch?v=1ByGlqV68BQ
https://www.youtube.com/watch?v=trP_aZcxx-0
https://www.youtube.com/watch?v=sngoIhxta9Q
ПОЛУЧИ БОНУС 1WIN ПРОМОКОД promo4win как отыграть на 1ВИН деньги как зарегистрироваться
ПОЛУЧИ БЕСПЛАТНЫЕ ДЕНЬГИ на 1WIN при регистрации ПРОМОКОД promo4win БОНУС 1ВИН 2025 на сегодня
ЗАБИРАЙ ЛУЧШИЕ БОНУСЫ 1WIN реальные ОТЗЫВЫ игроков о выплатах о выводе средств полный обзор бк 1ВИН
https://www.youtube.com/playlist?list=P ... kNdHo87ilD
https://www.youtube.com/playlist?list=P ... zv26QG6ILa
https://www.youtube.com/playlist?list=P ... cdbah_kiMX
https://www.youtube.com/playlist?list=P ... CW11CIBVFG
https://www.youtube.com/playlist?list=P ... 2P5RRrUAqQ
https://www.youtube.com/playlist?list=P ... DT9ilcKT7h
https://www.youtube.com/playlist?list=P ... MiRdzI-Qzr
https://www.youtube.com/@walangkwenta5018
https://www.youtube.com/playlist?list=P ... hgfzOJ_tfF
1WIN ПРОМОКОД при регистрации - promo4win - как зарегистрироваться на 1вин с бонусом promo 4win регистрация 2025 как отыграть бонус promo 4win
1WIN ПРОМОКОД при регистрации - promo4win - как зарегистрироваться на на сайте как зайти на сайт зеркало сайта 1вин как работает бонус promo 4win
1WIN ПРОМОКОД при регистрации - promo4win - как правильно зарегистрироваться на 1вин актуальное зеркало онлайн как забрать бонус в promo 4win
1WIN ПРОМОКОД при регистрации - promo4win - как зарегистрироваться в 1вин на телефоне зеркало скачать на андроид бонус по free spins promo 4win
1WIN ПРОМОКОД при регистрации - promo4win - как зарегистрироваться в 1вин зеркало рабочее на сегодня мобильная регистрация бонус promo 4win
1WIN ПРОМОКОД 2025 - promo4win - Как получить Актуальный бонус до 200 000? при регистрации по промокоду от 1вин Казахстан
1WIN ПРОМОКОД на сегодня - promo4win - получи максимальный Актуальный бонус от 1вин по промокоду при регистрации Россия
1WIN ПРОМОКОД на сегодня при регистрации - promo4win - ЛУЧШИЙ Актуальный БОНУС 1вин рабочий промо код на депозит 2025
http://www.glaschat.ru/glas-f/member.ph ... Cynthiavep https://forum.gorod.dp.ua/member.php?u=410288 https://forums.hi7ob.com/member.php?u=181235 https://htcclub.pl/member.php/164726-Cynthiadon https://forum.mma.su/member.php?u=18705 http://vn-info.net/user/Cynthiatem/ https://mainecoon-forum.ru/member.php?u=66734 https://gockhuat.net/member.php?u=28283 ... c1c45b9a83 https://www.hubtamil.com/talk/member.ph ... nthiaUphog https://forum.biblepay.org/index.php?ac ... le;u=35940 http://forum.d-dub.com/member.php?283839-Cynthiafar http://boss.why3s.cc/boss/home.php?mod=space&uid=107410 http://zeren.freeoda.com/member.php?act ... &uid=27366 https://forum.expert-watch.com/index.ph ... e;u=517834 https://istinastroitelstva.xyz/user/Cynthialor/ http://forum.roozgozar.com/member.php?a ... &uid=13224 http://phpbb2.00web.net/profile.php?mod ... le&u=98516 https://raritetno.com/user/CynthiaNof/
1WIN ПРОМОКОД на пополнение - promo4win - промокод 1win на пополнение promo 4win
Процесс регистрации с промокодом в 1WIN достаточно простой. Пользователь указывает базовые данные, выбирает удобный способ создания аккаунта и вводит промокод promo4win в соответствующее поле. После завершения регистрации код автоматически закрепляется за аккаунтом. Это важно, поскольку именно он активирует бонус при последующем пополнении счёта.
1WIN ПРОМОКОД - promo4win
1WIN ПРОМОКОД на фриспины - freespin4win
1WIN ПРОМОКОД на фрибеты - freebet4win
Отдельного внимания заслуживает ощущение контроля. С дополнительным балансом ты не зависишь от одного единственного хода. Ты можешь пережить неудачную серию, не вылетая из процесса, можешь перестроиться, сменить подход, выбрать другой темп. Для геймера это критически важно, потому что именно контроль отличает случайную игру от осознанного процесса. Промокод даёт не гарантию победы, а пространство для манёвра — а это куда ценнее.
Lucky Jet ПРОМОКОД promo4win Лаки Джет новая стратегия и тактика занос х100 большие выигрыши
Lucky Jet ПРОМОКОД promo4win игра Лаки Джет заносы и большие выигрыши с новой стратегией х100
ПРОМОКОД 1win Lucky Jet promo4win обзор новой тактики проверка реальные отзывы где играть
Как заработать на 1WIN Lucky Jet обзор, взлом, абуз, сигналы на Лаки Джет 1ВИН тактика и стратегия
Стратегия лаки 1WIN Lucky Jet абуз тактика на краш Лаки Джет 1ВИН Казахстан алгоритм как заработать
https://www.youtube.com/watch?v=RfR4JJHUCGc
https://www.youtube.com/watch?v=BUwo2z6Rp_w
https://www.youtube.com/watch?v=vvn6qDtbHZc
https://www.youtube.com/watch?v=djCa367BhUE
https://www.youtube.com/watch?v=VvRa3xJveS0
https://www.youtube.com/watch?v=GZdTP4pVuHw
https://www.youtube.com/watch?v=nzPlrDbYd9Y
https://www.youtube.com/watch?v=T6p2jJPqtPY
https://www.youtube.com/watch?v=IupSsLjyZLg
16
https://www.youtube.com/watch?v=bjQOoFcgtts
https://www.youtube.com/playlist?list=P ... CPfVc8AN34
https://www.youtube.com/playlist?list=P ... GF06dMPAO3
https://www.youtube.com/playlist?list=P ... 5_9DRuLOR-
https://www.youtube.com/playlist?list=P ... k4eEH4UoTP
https://www.youtube.com/playlist?list=P ... WGUFYbBD9Q
1win lucky jet с 500 рублей - Взломанный промокод lucky jet как играть на телефоне стратегия как выиграть с 500 рублей в 1win
lucky jet стратегия - Взломанный промокод lucky jet как играть на телефоне стратегия как выиграть с 500 рублей в 1win
lucky jet как выиграть - Взломанный промокод lucky jet как играть на телефоне стратегия как выиграть с 500 рублей в 1win
как играть в lucky jet на телефоне - Взломанный промокод lucky jet как играть на телефоне стратегия как выиграть с 500 рублей в 1win
выиграть в lucky jet - Взломанный промокод lucky jet как играть на телефоне стратегия как выиграть с 500 рублей в 1win
http://www.ufinance.it/component/k2/ite ... l?limit=10 https://eydosdigital.com/en/blog/item/8 ... mitstart=0 https://www.bayut.sa/blog/en/pulse/tea- ... ent-460183 https://mdai.aq.upm.es/blog/taller-de-i ... ent-211621 https://net-sah.org/content/41467?page= ... ent-117732 https://padraoepadrao.com/pt/component/k2/item/3]%D0%A2%D0%BE%D0%BB%D0%BA%D0%BE%D0%B2%D0%B0%D0%BD%D0%B8%D0%B5/ https://fortwaynesocial.com/sometimes-a ... nt-372826/ https://chocolatesclavileno.com/contacto/ https://beta-bauland.de/component/k2/item/6?start=0 https://kathrynfreeburg.com/hang-on-let ... ent-337381 http://www.espacovet.com.br/2018/01/26/ ... nt-1767290 https://ru.eech.online/masterserver/#comment-24682/ https://cup.myrevenge.net/index.php?sit ... =guestbook https://www.checkouttravels.com/product ... nt-419982/ https://buona.vn/tu-van-buona/tuvan/gia ... wer=272920 http://www.ailoflorence.org/events/loli ... ent-374298 https://www.hiddenagendalingerie.co.uk/ ... ent-960341 http://www.recovery.in.th/%e0%b9%80%e0% ... ent-849487 https://www.kathymarks.com/friday-after ... nt-7372488 https://conorkelly.ie/craniosacral-ther ... ent-58265/ https://www.ymaxuniversity.edu.mm/cours ... nt-1190809 https://www.troiaresort.pt/diversidade- ... ent-642650 http://tiptip.kr/bbs/board.php?bo_table ... id=1069012 http://moujmasti.com/member.php?227136- ... essage7313 http://bonedryretro.com/forum/viewtopic.php?t=386256 https://trigearflowmeters.co.uk/2017/05 ... ent-414364 https://wanep.org/wanep/chukwuemeka-b-e ... nt-1869564 http://daxuezhan.joinbbs.net/post.php?a ... ra=&page=1 https://travelbee.com.my/pure-luxe-in-p ... ment-65886 https://damasklove.com/diy-modern-apple ... ent-683240 https://dekorshop.com.ua/reviews/ http://156.226.17.6/forum.php?mod=forumdisplay&fid=2 https://www.forumtek.net/showthread.php ... post435895 http://forums.golfreview.com/sendmessag ... 9c84ff77fc https://digitallocker.co.kr/bbs/board.p ... _id=224855 http://www.sudanese.net/index.php?/foru ... 82/&do=add https://www.panevinomilano.com/location ... nt-777438/ https://udm88.net/webboard/viewtopic.php?t=109227 https://dgbak.co.kr/bbs/board.php?bo_ta ... wr_id=7843 http://leaderscom.net/bbs/board.php?bo_ ... r_id=71880 https://www.firstchoiceweddingcars.co.u ... nt-2518321 https://rorysaccounting.com/es/agencia- ... ent-53663/ http://www.khretech.com/bbs/board.php?b ... r_id=23111 http://forums.shlock.co.uk/viewtopic.ph ... 84#p500084 https://www.reconciliationsofnations.co ... ent-654636 https://hydrochem-e.com/bbs/board.php?b ... _id=406611 https://www.webmail.digitallocker.co.kr ... _id=224856 https://tonerconnect.net/blog/disable-e ... nt-1020091 https://blog.mccarthychevyls.com/2025/0 ... ment-38895 https://blog.beagrie.com/2008/12/22/new ... ent-791798 http://gurcuhaber.com/2023/09/11/%e1%83 ... ent-153154 http://onemoremarathon.co.uk/uncategori ... ent-276474 http://xn--04-f21is6v8stsqe.com/bbs/boa ... r_id=11799
16
