N1: Photo trigger is not available. Card is full, read-only or faulty. Check SD card. [solved]
allanimal
December 31st, 2018, 6:54 pm
I am able to connect to the Unleashed on my Nikon D500 from my iPhone SE , and I can change camera settings, but I cannot take any pictures. I am getting an error message "Photo trigger is not available. Card is full, read-only or faulty. Check SD card."
The card is empty.
The card is unlocked.
The card works with manual operation.
A 2nd card works ok.
Why does it think my SD card is faulty? What can I do to fix this so it works with all SD cards?
Nikon D500 FW C1.12 LD 2.015
iPhone SE 12.0.1
Unleashed N1 A1.0 B1.0 C1.1
January 1st, 2019, 10:37 am
There is a bug in the firmware that raises that error with empty SD cards. Take a picture with the camera and the error should go away.
This is a known issue and it will be fixed with the next firmware update.
