I have a Z6 ( latest firmware ) and iPhone 10plus firmware A1.4.4, B1.4.9, C 1.4.0 using USB cable.
issue: Set Camera to M, shutter to Bulb, Long Exposure to Time, then scroll past off to the times select any of those times and press shutter button on app and it immediately fires, no orange delay on any time.
If I select long shutter speeds up to 30 secs all works fine, select time and hold shutter button down works fine, select Bulb then Time - and select any time it fires no delay.
I have repaired, battery out, unplugged cable no change - all works fine apart from this feature.
Best Regards
Chris
Z6/iOS Long Exposure Time issues
Hi Chris,
Sorry for the trouble. This is an issue known to us. Unfortunately, there is a small bug in the app that causes the Unleashed to stop the long exposure to when you release the trigger button in the app.
A workaround for now is to tap the button as quickly as possible, so that your finger has left the button before the app knows that the Unleashed has started the long exposure shot. Our iOS developer knows about this and the fix will come with next release.
