timelapse not taking sequential photos [solved: 30s actually 32s]
Posted: August 4th, 2020, 12:04 am
				Hello
While shooting a timelapse of stars for the purposes of making a startrail photo I ran into some issues getting unleashed to take the next photo in the sequence. I had previously done this with no issue) I set an exposure of 30 seconds and set the interval to (31 seconds this was the minimum it would allow before ungreying the start button) give it enough time to process, making sure the start button was not greyed out and there were no other warnings. Sometimes it would finish the photo and THEN wait 31 seconds before taking the next one. Ideally I want it to start the next photo as soon as the previous one is finished so there are no gaps in the startrails. Does the interval between photos begin counting at the beginning or the end of the photo? I don't know what happened but after updating firmware it seemed to work OK. Is there any reason this might have happened? Could it happen again?
Thank you
Dave
Thank you
Dave
