Battery Drain
Tmiller225
May 12th, 2019, 5:16 pm
Unleashed causing Nikon D7500 battery to drain even when the app is closed out and the camera is turned off. What options are there for reducing battery drain?
May 20th, 2019, 7:24 pm
Hi TMiller,
try the latest app & firmware update, we did quite a bit to save battery power.
If that doesn't solve your issue (we're still continuing to improve power consumption), If you don't plan to use the camera for several weeks, you might want to unplug the battery of the camera, which is easier than unplugging the Unleashed. Might as well keep the battery in the charger so it's completely charged once you do want to use the camera again! ;-)
