Sunrise test on Canon R7 – only TV correction, no ISO
mopperle
September 12th, 2025, 10:02 am
Dont expect any answer from foolography. They are dead and/or not longer interested in providing support. An annoying situation since a year now.
Trying to help you:
ISO -> TV means that first the ISO is going to be changed and then after reaching the ISO limit you have set, TV is changed. So it depends on the ISO value you have choosen. So it might be normal that ISO ist not going to be changed.
Otto
September 12th, 2025, 7:12 pm
Trying to help you:
They had tons of warnings and feedback given by users, supporters, customers, etc, but they ignored their loyal customers. They even ignored the clear evidence given to them by technical experts that gave them so much valuable help during the development process, but they had too much pride to abolish and ignore the feedback they were getting. They saw it as personal criticism (their "baby") instead of criticism of a flawed design (the design was flawed, not the people behind the design), while the feedback was to inform them of changing course, not changing their goals. They refused to listen and now the situation is a dead-end street were they couldn't get out of without doing a recall of the product. Terrible situation, but they got themselves into this mess because they kept on going in the same state of mind that did not promise much good for them and their customers. This is sad, but true. If only they had listened to good advise... The Unleashed product of 2018 was flawed in design, but to repeat the same mistake twice is not a development fault, but a subborn mentality problem that caused them to not redesign the hardware and software for the Unleased 2022. Repeating the same mistakes twice is a sign of limited selfreflection and an overall bad concept of the reality you are in. As Albert Einstein said before: The definition of insanity is doing the same thing over and over and expecting different results. They had their chances to undo their previous mistakes made in the 2018 version and not repeat it in the 2022 version. They did not. Instead, they used a flawed foundation as their base design and built on top of that for other camera brands. That can only go well, if the base design is cleaned of any flaws made in the previous design. Ironing the flaws out of it should have been top priority for them. They chose differently. What you now see is the end-result of bad choices. I find it a tragic situation for all: themselves and their (loyal) customers. Nobody benefits from a company going sour. If only...
This is a clear case of not listening properly to the feedback you receive and discern the difference between critisim to pull down or ciritism to build up. Not all feedback that is mentioned is helpful, but the feedback you get from different persons, levels and devices, should tell you that something is not going right. Ignoring that, is ignoring your customer. And in the end your company does not benefit from the early warnings given. When you have received too many warnings, you have lost your ability to change course so that you achieve the goal you had in mind: a working product with the specifications and marketing promises given beforehand to your loyal customer base.
