Unleashed 22 won't exit Holy Grail Mode without Factory Reset
Posted: October 17th, 2024, 8:36 pm
by GliderGuider
I have two Unleashed 22's, an N1 for a Nikon Z8 and an N2 for a Z6II. Both work fine in everything apart from Holy Grail. When in Holy Grail and on activating the Algorithm to one of the available options they both do a decent job of ramping. However when I want to go back to Timelapse neither of the Unleashed units allow me to select Algorithm 'Off' they just stay on the algorithm and if left at Off in the selector they revert to EV 24h.
The only way to get out of Holy Grail, I've found, is to Unpair the Unleashed, re-pair it, then do a factory reset. This clears the issue in both units and allows me to use Timelapse mode.
If I try to go into Timelapse mode without doing the above they both say Timelapse is unavailable as Holy Grail is running.
Also the N1 unit only gives me the EV 24h option whereas the N2 unit give me the four LRT Beta options plus EV 24h
I am running the latest firmware A 3.5.0, B3.5.1 & C 3.3.1
Clearly there is a bug causing this - can the team fix this issue at the next update?
Re: Unleashed 22 won't exit Holy Grail Mode without Factory Reset
Posted: July 30th, 2025, 6:28 pm
by PapaBear
The only factory reset I can think of right now is to throw the thing away for good and never look back.
Posted: August 3rd, 2025, 9:48 pm
by GliderGuider
Both my N1 for a Z8 and N2 for a Z6II are now on firmware A: 3.6.3 and the issue of moving from Holy Grail to Timelapse has been resolved without having to do a reset.
I have found that while in Holy Grail mode once the Algorithm has been set to EV 24h on the N1 or LRT Beta's or EV 24h on the N2 it appears that they still cannot be turned back to 'Off' - not necessarily a problem now though as I can swap back to normal timelapse easily.
However, we are still missing the four LRT Beta options in the algorithm list on the N1 Unleashed 22's - can these be added please?
