Nikon Z9, Unleashed '22 bracketing issue
Posted: April 12th, 2024, 9:05 pm
Hello!
I have Unleashed '22, current firmware as of today (2024-04-12), paired with my Nikon Z9 (firmware 5.0).
When I select and run bracketing using my Unleashed '22, the camera takes 3 shots for each exposure level in the sequence. This was true on older firmware versions for both the camera and Unleashed.
So, if I set up a bracket sequence that should take 9 exposures, I end up with 27 frames. At each exposure level, the camera takes 3 shots. HDR overlay is disabled in the camera (the only culprit I could think of) so I have no idea what's causing this, nor how to make things work properly.
This happens on all the lenses I've tried, including Nikon Z lenses as well as manual lenses (e.g. Laowa 15mm macro wide-angle).
Hoping someone can help please.
Jerry
Jerry
