No, it's the right cable, we only have one version of each of the HDMI cables.
I know it's not ideal for this one camera, but at least 95% of cameras have the HDMI sockets oriented the other way round, so we had to optimise for that. The Sony A7R IV is one of the few exceptions.
However, you don't need to worry about it not lasting! The cables are designed to be extremely resilient. they have extremely flexible strands of wire inside, and the insulation is made of TPE, both of which means that you can bend it as tightly as you want to, pull on it, pinch it and treat it quite harshly without risking any damage!
That said, you did do something wrong: it's plugged into the Unleashed the wrong way round! There is a slot and key that should stop you from doing so, but because the casing is plastic, it’s possible to overcome this. But don't worry: we designed it so that even if you do manage, it won’t break anything - it just won’t work.
The LED won't light up, the Unleashed M won't get any power so it won't show up during pairing.
On the Unleashed M, plug the cable into the the Unleahsed so that the cable points toward the right, ie toward the back of the camera.
In your case, with the Unleashed rotated to the right by 90º, the cable needs to point downward.
I'd recommend guiding the cable around the bottom of the Unleashed then up again between Unleashed and flap.
I hope that helps!
Please have a look at our getting started page, the info about this is on there too, as well as how to prepare your camera - again, the A7R IV is a bit special:
