Not lighting up
chacabuco74
January 12th, 2024, 6:12 pm
I am using the Unleashed 2022 with a gfx100. I set it up a few weeks ago, and everything was working fine. I unplugged it for a while, and now, when I plug it back in, it doesn't light up at all. Not discoverable by the app either. Any ideas?
Thanks
January 15th, 2024, 11:36 am
Could it be that you have managed to insert the cable into the Unleashed the wrong way round? There is a slot and key that should stop you from doing so, but because the casing is plastic, it’s possible to overcome this. But don't worry: we designed it so that even if you do manage, it won’t break anything - it just won’t work.
The LED won't light up, the Unleashed M won't get any power so it won't show up during pairing.
On the Unleashed M, plug the cable into the the Unleahsed so that the cable points toward the right, ie toward the back of the camera.
I hope that's all!
