No Function Lumix G9
Posted: October 13th, 2023, 6:18 pm
by iPet
All function after connected to my Lumix G9 are disabled. Error: Wifi is on - but Wifi is off....
Re: No Function Lumix G9
Posted: October 20th, 2023, 8:55 pm
by bjn2
Be sure you set the camera's USB mode to PC(Tether). My G9 works using this setting. However, there is no geotagging. I see that there's a footnote about geotagging working "with some limitations". The app says geotagging is not supported on the G9, and that's NOT my expectation from the "with some limitations" features listing.
Posted: October 24th, 2023, 9:08 pm
by iPet
What firmware has your Lumix G9?
Posted: October 25th, 2023, 9:47 pm
We added Geotagging for Panasonic fairly late, so you'll need to be on Firmware version 3.0.0 or later. We always recommend installing the latest update!
Did you follow the instructions to set up your camera as described here?
PANASONIC LUMIX
  • Set the camera setting: MENU > Setup > IN/OUT > USB > USB Mode = PC(Tether)
  • Set the camera setting: MENU > Setup > IN/OUT > USB > USB Power Supply = OFF
I hope this helps
Posted: October 27th, 2023, 8:01 pm
by iPet
I'm using Lumix G9 with Firmware 2.7 and I got no connection to the Camera.
Posted: November 4th, 2023, 9:37 am
we issued another firmware update for the Unleashed this week. Could you install that and try again?
Posted: April 5th, 2024, 12:09 am
by bjn2
After much fussing and several failed attempts, I was able to update the firmware. The GPS icon shows an X despite the app having location permission. Phone is a Google Pixel 7a.
