I just received Unleashed 22. First time that i connect it warning about firmware update. So i update firmware 2.xx it to firmware A, B, C 3.0.0.
I install Unleashed in my Sony A7RV to test. It working on every menu Photo, Video, Timelapse and Bracket except Holy Grail menu that not working properly.
No matter i choose Algorithm, Ramping order or any interval. The Unleashed will start timelapse but not change shutter speed, F or ISO as light changing.
I can only change exposer if i change "Adjust" manually.  I try to change My A7RV quality setting to RAW+ JPG small or only JPG and change camera menu to send JPG small to connect device but Holy Grail still not working.  I connect it with Unleashed app  3.0.1 on my Iphone 8+.
Any comments and suggestion will be appreciated. Please fix this bug.
													Unleashed 22' Holy grail not working with Sony A7RV [solved with FW 3.0.1]
I have the exact same problem with the unleashed'22 that I just received on my Sony A7III  (not R)
My camera is a A7III (firmware 3.10, rather than 4.10), firmware of the unleashed and the app software are both up to date.
Android 13, up to date.
Camera (!) crashes and resets whenever I don't set it to save jpegs, but only raw.
When I do save jpegs, the timelapse takes pictures, but the ramping does not work. The entire timelapse is taken at the initial settings.
Is there another update planned for this?
