IPad connects but new iPhone will not pair [solved - only 1 connection at a time]
Posted: August 18th, 2022, 8:48 pm
by Amesda
I have pairing with iPad but new iPhone will not find my unleashed. It is on camera, camera is on and I can see green light on Unleashed. I deleted app on phone and reinstalled, turn phone off and on. Can the Unleashed be run on two devices? Is that the problem?
Re: IPad connects but new iPhone will not pair
Posted: August 19th, 2022, 6:31 pm
Hi Amesda,
You can't be connected with two devices at the same time.
you can pair the Unleashed with both devices if you want, but only one can connect at a time.
If the LED is turquoise, then it's already connected to a device and won't allow another connection.
So you first have to disable it in the iPad to be able to pair & connect on the iPhone:
Menu -> Unleashed with gear icon
toggle the switch to the right of your Unleashed displayed at the top. then it will disconnect and you can pair on your iPhone.
