Set Nikon camera in CL or CH release mode, attach a flash, use the Android App, press ONCE on the button to trigger camera ONCE.
Result: endless looping of taking pictures by the Unleashed/Camera. Not possible to stop. Even when camera turned OFF and ON again. Unleashed keeps looping and triggering the camera. Only thing that works is pull out the battery of the camera to make it stop. Camera and Flash go berserk!!!
Could this be fixed ASAP? It is annoying because now I can't use the CL and/or CH release modes in the Nikon-specified way. So, I can't use the Android App to remotely trigger the camera. Have to return to a wired set up (again). Back to the old days, which is not preferable.
TIA!
FlatWorm
[edit: typo]
						Endless Looping / Repeated triggering when Nikon camera set to CL or CH release modes
Sorry for the trouble! Which camera are you using? And which firmware version are you on? To find that information:
App menu → Unleashed icon in bottom left → tap on your Unleashed → tap "Firmware"
