USB is not working anymore [solved - cable inserted in reverse]
Posted: October 12th, 2021, 5:02 pm
So far I worked with a Nikon D7500 without the USB cable connected.
Yesterday I wanted to use my Nikon D7000 with the USB cable and an adapter USB mini male to USB Micro (D-Lock Nr.65155). But it did not work, I could not set anything, saying USB cable unplugged.. Going back to my D7500 to check USB cable, I recognized that the camera accepts one setting and one shot and then blocks. Also Picture review does not work. With unplugged USB the Unleashed seems to work as it should. My order number was order #19698 in May 2021.
Any Idea? Do I need dedicated cable from you for N2 to D7000?
