After updating my Sony a7CR to the newest firmware 2.00, I can´t set any other shutter speed than BULB anymore. In the app it always switches back to BULB if I set any other shutter speed. I made a video that shows the behavior: https://imgur.com/a/m1Fojob.
Once I set it to BULB, it doesn´t switch anymore, but then the fastest setting I can choose is 1s in "Langzeit" as a workaround, but that doesn´t make sense in most cases.
Sony a7CR Bug after Firmware Update 2.00
I can confirm I have the same issue with a Sony A7C II, Firmware v2.00
I bought the unleashed '22 in June 25, my camera was already updated to the latest firmware which was released in April 25, and unfortunately have never been able to use the unleashed since because of that annoying bug that make it unusable, even by also updating the unleashed to the latest firmware (v 3.6.3 actually)
I hope the dev will be able to fix it soon, because actually, it's the most expensive (unusable) cam remote I ever bought ;/
Don't have high hopes of getting a solution. If you get a solution, it would be a miracle.
We have seen many broken promises repeat itself here. There is still, after all those years, no solution to the battery draining problem.
I do hope I am totally wrong about this, but I don't think so in the long run.
@Oliver (admin)
do you think you'd ever address this bug?
I bought the unleashed last spring, and have never been able to use it because my sony A7cII was already upgraded to firmware 2.00
As you never answered to my refund request, nor to this thread, I feel like the support from your company is non existent...
