No geotagging with Panasonic G9 - specs say geotagging with "some limitations"
bjn2
October 20th, 2023, 9:14 pm
Geotagging from the app is the big reason I backed Unleashed 2 for use with my Lumix G9. I already have an '18 version that works well with my Nikon Z6. With the G9 and my Unleashed M, the app shows a grayed-out GPS icon with the "i" GPS Mode is not available. This camera doesn't have this feature. The specs say that geotagging is supported, but there's a footnote to the effect of, "3 Supported - with some limitations" for all Panasonic cameras. There's no explanation of the limitations, but having zero geotagging capability isn't my idea of "supported". The Lumix Link app provides geotagging via Bluetooth. With my Nikon body, the Foolography dongle and app work more reliably and seamlessly than other Nikon control apps I can use.
What exactly are the geotagging limitations for Panasonic cameras?
October 23rd, 2023, 1:59 pm
We added quite a few features after the production, so it's important you do the update! I don't know of any reason that Geotagging would not be supported on the G9. It's not quite as nice as on your Nikon, but it works nonetheless.
bjn2
November 23rd, 2024, 5:25 pm
Thanks for your reply. I have location tagging working, but I had to do some digging to figure out how.
I recently switched from a G9 to a G9 II and also had no luck getting GPS tagging to work until I found the Bluetooth in-camera setting necessary for GPS tagging with Lumix Sync. The start instructions here for Panasonic mention turning tethering on under USB/Mode in the camera's menu, but they do not mention turning on "Location Logging" in the camera under the Bluetooth settings. With Location Logging turned on and with Bluetooth enabled, a GPS icon appears on the camera's display. When connection is made and GPS data becomes available via the Foolography app, the grayed icon becomes white. It does take several seconds for location to become active after pairing with the app. The same is also true of the Lumix Sync app.
After some digging I understand now that GPS tagging works for Panasonic via Unleashed, but with the limitation that it does not work simultaneously with remote control functions.
danb121
November 25th, 2024, 11:32 am
I can't get GPS working with full camera functionality on my Canon either; to make adjustments to the camera settings I always have to switch GPS off make the change and then turn the GPS back on, but this only works in photo mode, timelapse/holy grail aren't usable when GPS is on which is a huge inconvenience, especially when you pay €230 for the privilege! I haven't figured out a way to GPS tag in timelapse or holy grail mode, and I guess that the same would go for bracketing too, so it's a very limited device in my opinion, that no one bothers to respond to support emails or question on the forum.
Dan
