Unleashed not working with Canon R7 [solved with FW 3.0.2]
croimans
October 24th, 2023, 2:31 pm
@croimans: just try it without any SD card, so we can confirm that your seeing the same issue for the same reason that we found.
Will to after 3hours when I'm home.
Will play around with it to see what I get of response in Unleashed app.
Keep you posted
croimans
October 24th, 2023, 9:38 pm
Removed memory card still the same problem.
Can't shut off camera, it hangs, and as you can see in Unleashed app settings not possible and when touch anything het the message "still initializing please wait"
croimans
October 30th, 2023, 8:49 pm
any updates on the matter or do we stay with an Toy we can't use ?
It is said Camera model Canon R7 is supported, so i expected it would be working, but product does not work as advertised,
October 31st, 2023, 11:57 am
Android App was updated today, Firmware update is scheduled to be released tomorrow.
November 1st, 2023, 10:28 pm
Firmware update 3.0.2 was released just now. It fixes the issue on all the R series cameras we were able to test with!
I hope it will fix it for you too!
We made lots of other improvements too, such as Gallery on Canons with two card slots, Geotagging on Canon R series, and more!
croimans
November 1st, 2023, 10:58 pm
When does the new FW come online?
And FW release notes can we see or read them somewhere?
November 2nd, 2023, 12:17 am
It's already online. You should see a red notification badge in the app. If you don't already see it, you can just restart the app, and it should be there. When you follow the red notification badge to the firmware update screen, you'll see the release notes there.
With the Unleashed M, you need to keep the camera awake, so that the Unleashed stays powered during the entire update. To keep the camera from entering standby, half-press the cameras's shutterbutton continuously or regularly until the update is done.
bglana
November 2nd, 2023, 10:16 am
I did the firmware update but it looks really weird as the problem doesn't looks solved.
Camera is freezing and the only solution is to take out the battery.
Groß (Bildschirmfoto 2023-11-02 um 10.12.22).jpeg (47.32 KiB) Viewed 138982 times
croimans
November 2nd, 2023, 10:41 am
For me it does work after this update.
Shouldn't there be a preview on app what camera sees?
November 2nd, 2023, 11:32 am
That's great to hear!
We do have Image Review, where you can get a smaller "preview" image after you take a shot. But we don't support live-view, if that's what you're looking for.
We try to be as clear as possible about this, but unfortunately it is still misunderstood by many, because once you assume it should have live-view, it's easy to interpret what we write to support that assumption.
The name for a lower resolution version of the original image on the SD-card is "Preview Image", so that might come up here and there in our texts, but we did rename the feature to "Image Review" rather than "Preview" many years ago to avoid such misunderstandings...
Especially on Canon Live-view is simply not feasible via Bluetooth Low Energy. The smallest live-view frame on Canon is around 200KB so even if we got to the absolute theoretical maximum of Bluetooth Low Energy, we could still do less than one frame per second. And in reality, the best we could do was closer to one frame every 3 seconds. Since we know we would have gotten even more complaints about this, we decided against offering a sub-par feature.
