No Function Lumix G9
Be sure you set the camera's USB mode to PC(Tether). My G9 works using this setting. However, there is no geotagging. I see that there's a footnote about geotagging working "with some limitations". The app says geotagging is not supported on the G9, and that's NOT my expectation from the "with some limitations" features listing.
We added Geotagging for Panasonic fairly late, so you'll need to be on Firmware version 3.0.0 or later. We always recommend installing the latest update!
Did you follow the instructions to set up your camera as described here?
PANASONIC LUMIX
PANASONIC LUMIX
- Set the camera setting: MENU > Setup > IN/OUT > USB > USB Mode = PC(Tether)
- Set the camera setting: MENU > Setup > IN/OUT > USB > USB Power Supply = OFF
we issued another firmware update for the Unleashed this week. Could you install that and try again?
After much fussing and several failed attempts, I was able to update the firmware. The GPS icon shows an X despite the app having location permission. Phone is a Google Pixel 7a.
- Failed update attempt 4 - Unleashed always had power - connection would be lost and I'd have to restart each time
- Screenshot_20240404-153736.png (132.58 KiB) Viewed 18993 times
- GPS status after update
- Screenshot_20240404-152558.png (135.49 KiB) Viewed 18993 times
