[solved] Firmware Update Nikon D7000 failed
KhunOtto
May 19th, 2022, 2:13 pm
After month in Hospital i tried to reactivate my Unleashed Hardware on my Nikon D7000 but ended up with a mess, the LED is blinking red and the update process stucks at 0%
don't know why the image doesn'T show up correct, here'S the link to my web http://www.stereomusic.at/tempUL/D7000unleashed.png
any help would be appreciated
by(e)
Khun Otto (ออตโต้ ซเติฟคา)
May 22nd, 2022, 12:40 pm
Hi!
I see that your serial number is below 4500, so we almost definitely have a fix for you. You will not believe this but the following trick will almost definitely help: Put the Unleashed in the freezer for 10-20 minutes, then plug it into the camera and try the update again, while it’s still as cold as possible.
We took a long time trying to find the cause of this problem. We found the problem and fixed it, but the fix comes in Firmware A, so if there’s ever a problem during the update of Firmware A, the fix will no longer work either.. The trick with the freezer has a scientific explanation too - now that we know the underlying cause.
I hope it helps!
KhunOtto
May 23rd, 2022, 8:41 am
after half hour in the freezer the hardware was cold, plugged in my Nikon, but can't even connect to the app
http://www.stereomusic.at/tempUL/Screen ... 080847.png
only red blinking from the LED
http://www.stereomusic.at/tempUL/VID_20 ... 080926.mp4
any help would ne appreciated
BTW i wrote an e-mail in german language also, if you prefer to answer there
by(e)
Khun Otto
May 25th, 2022, 3:23 pm
Please try again a couple of times. We've had several cases where it only worked after the 3rd or 4th try.
KhunOtto
May 27th, 2022, 12:24 pm
the third attempt was successfull, thx for this hint - unbelieveable but true hahaha
best regards
Otto
May 27th, 2022, 9:45 pm
Excellent, I'm glad to hear it!
Enjoy your Unleashed!
