In the screenshot it looks like the Unleashed thinks the Shutterbutton is fully pressed. Although very unlikely, it's possible that there is a hardware issue that was missed by our tests.
Could you unplug the Unleashed, plug it in again, don't press the shutterbutton in the App, but just leave the app open watch the shutterbutton in the app. Then halfpress the physical shutterbutton on the camera a few times, then fullpress the shutterbutton on the camera once or twice. Does the button get a little smaller when halfpressing and even smaller when fully pressing?
can you do a screen-recording that you can send us?
Thanks, and sorry for the trouble.
No photo Z7 [solved: hardware defect]
ok, ik heb de unleashed losgekoppeld en opnieuw aangesloten
dan zie ik dit: bijlage : screenshot onaageroerd
bij half indrukken: t volgende screenshot
en bij afdrukken op camera de volgende : ( met een gele ring)
- Screenshot_20210205 camera geheel ingedrukt neemt foto.jpg (193.33 KiB) Viewed 16067 times
- Screenshot_20210205 ontspan camera half in gedrukt.jpg (185.92 KiB) Viewed 16067 times
- Screenshot_20210205 omaangeroerd.jpg (186.27 KiB) Viewed 16067 times
Thanks for the screenshots.
it does indeed look like what I was worried about - the pin responsible for the "full press" seems to be disconnected. We'll have to send you a new unit. Sorry about that.
Can you please write to support@foolography.com with your order number and a link to this thread? Please also confirm that we should send the replacement to the same shipping address as in the original order, or send us a new shipping address.
