Minimum 2 Second Interval?
I believe that's true only for autoramped timelapses (holy grail timelapses). That's because the Unleashed needs some processing time to calculate the next set of setting values, I believe this is already explained in an error message in the app. 1-second intervals should be possible in the normal timelapse mode.
Maybe I have missed it, but with normal timelapse not able to use interval less than 2 seconds. With any shutter speed minimum interval is 2 sec or there is an error with Nikon Z6.Andy wrote: ↑January 4th, 2021, 9:12 amI believe that's true only for autoramped timelapses (holy grail timelapses). That's because the Unleashed needs some processing time to calculate the next set of setting values, I believe this is already explained in an error message in the app. 1-second intervals should be possible in the normal timelapse mode.
This could be a rounding error in the Apps. the requirement is that Interval is greater or equal to shutterspeed+1s. The most likely issue is that shutterspeed, which is never 0, always gets rounded up to the nearest second, (which would be 1), then the minimum pause is added, to become 2s.
I'll ask our app developers to check this, but as Andy mentioned, the limitation will be lifted in the next release anyway.
Are you using Android or iOS? the rounding might have been implemented differently between the two, without us noticing.
That makes sense, I am using IOS.Oliver wrote: ↑February 15th, 2021, 10:54 amThis could be a rounding error in the Apps. the requirement is that Interval is greater or equal to shutterspeed+1s. The most likely issue is that shutterspeed, which is never 0, always gets rounded up to the nearest second, (which would be 1), then the minimum pause is added, to become 2s.
Unfortunately this is not correct. Using the Nikon Z6 or Nikon Z7 II (the two cameras I have), in timelapse mode, the minimum interval allowed is still 2 seconds. I'm also using the IOS app.Andy wrote: ↑January 4th, 2021, 9:12 amI believe that's true only for autoramped timelapses (holy grail timelapses). That's because the Unleashed needs some processing time to calculate the next set of setting values, I believe this is already explained in an error message in the app. 1-second intervals should be possible in the normal timelapse mode.
Do you have an ETA on when a firmware update might fix this problem?
I am using IOS with a Nikon Z6 and Nikon Z7 II. To which release are you referring and when will that be available? Thank you!Oliver wrote: ↑February 15th, 2021, 10:54 amThis could be a rounding error in the Apps. the requirement is that Interval is greater or equal to shutterspeed+1s. The most likely issue is that shutterspeed, which is never 0, always gets rounded up to the nearest second, (which would be 1), then the minimum pause is added, to become 2s.
Since you're on iOS, you're very welcome to join the beta: viewtopic.php?f=13&t=928
We can't yet promise a release date for the final version of this firmware, as we're still beta-testing. Also, our Android app still needs to do some catching up with iOS before we can do a public release.
Any chance that the Android users can have an intermediate firmware update before a new App version is released with all the new features already contained in the iOS App?
I am eagerly waiting for a firmware update and App update that has the "suddenly trigger the camera's out of the blue"-bug, as mentioned a very long time ago on this forum (ask Andy if you can't recall that bug-report). The randomly triggering bug is somewhat annoying in the current firmware/App. Especially when taking pictures in a home setting (like with birthdays, family dinners, etc).
I know you can't give an ETA of the new App release, but could you please consider a stripped-down firmware update, so that those bugs are resolved. Then you can release a new App update with all new features later on. My concerns are to get those bugs out of the system, which do trouble me in normal operation mode.
Thanks in advance.
