Unable to Use Rear Monitor while Unleashed Is Plugged in [solved: hardware defect]
October 16th, 2020, 12:47 pm
October 16th, 2020, 10:01 am
@Unfoolishly: Don't worry, your Unleasheds are not affected for sure.
It was just a small number of mainly N1's (some N2s) in the first production batch (ie Kickstarter backers), with serial numbers below 1000. Most Unleasheds in that Production batch are without any issues, so it's not a widespread thing. That's why we can't specify which serial numbers exactly, but can only handle this case by case.
Okay, just making sure I don't end up in the same position with the Unleasheds I have. Mine are in the 003xxx range, and still working :-)
slp
October 16th, 2020, 4:23 pm
@Oliver, thank you.
slp
November 9th, 2020, 11:39 pm
It took about three weeks, but the Unleashed finally made it to you.
Screen Shot 2020-11-09 at 5.35.59 PM.png (49.98 KiB) Viewed 21286 times
slp
November 24th, 2020, 2:36 pm
@Oliver,
My Unleashed arrived yesterday and the camera is working properly now. I will continue to test it, but so far it looks good. Thanks for getting it fixed for me.
November 24th, 2020, 2:54 pm
I'm glad to hear that!
have fun and enjoy your Unleashed!
