Hey Oliver,
I was looking through my mails, but could not find a debug build or anything. Any update on this?
Matthias
Help - Unleashed does not connect (again) [solved in app update 1.3.7]
Hey Oliver,
Maybe it takes a while, but for now nothing arrived yet. Are you sure you used the right mail address?
Not sure how we can verify the mail address again ...
Matthias
Matthias
AperturePerception
I'm getting the same thing on Nikon D500, tried everything as mentioned earlier on this topic.
For me however, I'm on Android 9 still and haven't been working for the last month and a half.
Carlos
Carlos
Hmm, that's odd. I guess gmail deletes emails with apps in the attachment for security reasons...
I have the right email.
yep, found this:
yep, found this:
I'll send you another email without anything, and then another with a link.Google has now decided to prevent everyone from using APK via email - they artificially block all emails that contain a .APK attachment, and their help article says they will not fix this and will not allow anyone to disable it. Score -1 for anyone unlucky enough to have a gmail address.
The invitation arrived today. Thanks!
I reproduced those cases (good case after install, bad case after phone restart, good case after deleting bluetooth and app data as well as my GPS issue) and sent them back to info@foolography.com
Let's see whether this helps.
Matthias
Matthias
hi,
I just experienced the same issue on a Sony Xperia XZ Compact on Android 9 (!!!) (build 52.0.A11.32) after trying to use my Unleashed after a few months. the strange thing is that I can pair the Unleashed from the system but not from the app. the app though does see the dongle and I can tap pair but it never connects afterward. I am just charging the original Nikon battery which I had to swap with a different make and will test to connect again with the original battery in place.
clearing the app cache/data didn't change anything for me. I also restarted my phone, re-installed the app, etc. - all without success.
br
Mario
br
Mario
