Hej,
my new Unleashed has just arrived but I only get the Error 70. My Camera Model is an Eos 60D. If you need more information, please feel free to contact me.
Hi, and sorry for that.
We fixed many Error 70's on Canon, but saw a new one with an older camera that we hadn't tested - the 550D - at photokina. I assume yours will have the same issue.
We're in the process of getting a camera like that, to fix the issue as soon as possible. Sorry you have to be even more patient after such a long wait already.
Does it happen from the very beginning? or do you do anything in particular (eg change a setting, switch on GPS,...) to get that error?
				HannsGeorg
I came back to your booth at Photokina after receiving Unleashed for my 60D because I couldn't find the android app. Wasn't releases yet. Only now I can tell you that I have the Err 70 on my camera (4 digit serial number) and also on the newer 60D from my company. The orange/green/yellow LED is blinking very slowly...
Disappointed regards
Hanns Georg
Hanns Georg
				HannsGeorg
I forgot to mention : firmware version 1.1.1 on both cameras.
Hanns georg
						Hanns georg
- TheRealTimYoung
sorry for the x post, but yeah I've a 60D showing error 70, tried everything cannot get my camera to work with Unleashed plugged in. Interesting to know how you're going to fix this remotely, is it even possible?
						Alright, thanks for your input. Now we know for sure it's not just a one-off issue, but that it affects these two camera models, and maybe more.
Sorry for the disappointment - but don't worry: it won't last. We're looking into the issue and I'm sure we'll fix it.
						Hi, I have the same Error 70 on my Canon 60D. I just installed the latest firmware version (1.1.2) to see if this changes anything. Unfortunately not :-( Error still occurs.
I also have a 5D Mark II which I unfortunately cannot get to work either. There I was able to connect to the app shortly but it gave me an USB error and when I tried to replug it in it stopped working completely. There is no little light on the unleashed, it just stays black now..
